Rainbow problem when full screen
Go to solution Solved by PeterPorkey,
fixed it with a reinstall of windows 10. its all good now. leaving this for anyone that has the same problem,
Hey guys I know my laptop is old but it's the only one I have and I can't afford a new one. I'm having problems with some full screen apps. Everytime I fullscreen an app like Dota2, VLC, Genshin Impact, the colors get messed up. Like red turns to blue etc. While for Valorant the entire screen just turns into a rainbow mess. For Valorant however when any windows UI shows up like the volume adjustment the colors turn to normal, this is also happening when I quickly switch from full screen to windowed then back to fullscreen. Here are some photos, sorry if they are pictures taken from the phone, somehow the screenshots are normal color.
Here are the specs
  • HP pavilion 17 Notebook PC
  • Windows 10 Home 64 bit
  • Amd A8-6410 APU with Radeon R5 Graphics
  • Stock 6GB ram
  • Stock 1TB HDD
https://linustechtips.com/topic/1340609-rainbow-problem-when-full-screen/
2 minutes ago, Khuulzz said:
Maybe try to run a clean installation, did that when Cold War crashed on me every other game and it worked.
But i do not know how it works with AMD graphics you would have to look it up on YouTube
If you mean clean installing the display driver I did that too 😞
  • 9 months later...
hi i have the same issue as well i tried to reinstall windows 10 but didnt work. By any chance do you mean by reinstalling all of my pc data should be removed cause i kept everything and reinstalled it and it didnt work. Please reply to my message as fast as you can because my pc is lagging a lot
  • 1 year later...
