Budget (including currency): £2250 GBP
Country: UK
Games, programs or workloads that it will be used for: Apex Legends, Cyberpunk, Shadow of the Tomb Raider, CSGO, Minecraft
Parts on list:
Ryzen 9 5950x (already purchased)
H510 elite white
Kraken x53 240mm AIO
Radeon rx5500xt (planning on upgrading to the 6800xt when the scalpers stop scalping, also already purchased)
Samsung 980 pro 1TB
ASUS ROG Crosshair VIII hero
32gb (4x8gb) G.Skill Trident Z RGB
Windows 10 Professional
NZXT C750 80+ Gold PSU (Fully Modular)
Any help or advice is appreciated 🙂
https://linustechtips.com/topic/1340392-advice-for-a-build/
Country: UK
Parts on list:
H510 elite white
Samsung 980 pro 1TB
Instead of Windows pro get home theirs like no difference at ALL!
To save money instead you can go with (2x16gb) of the same ram if you want I can give you the link to amazon.
Instead of that case go with a Phanteks case
OR
A Corsair 4000d airflow case.
https://linustechtips.com/topic/1340392-advice-for-a-build/#findComment-14751177
if you dont care about RGB, i would rather go for the arctic liquid freezer II cooler. its much better and much cheaper too. There is a GamersNexus review if you want more details. the samsung pro drive seems unnecessary. for a gaming machine, the extra speed will hardly make any difference especially when other drives are cheaper and perform almost the same.
Edit: that case does not have good airflow so your temperature will be higher
https://linustechtips.com/topic/1340392-advice-for-a-build/#findComment-14751179
for a high end build like this, 4 sticks is going to look nicer and having dual rank dual channel is going to help performance
there are actually some differences that are deal breakers for some. I would rather just get a windows 7 ultimate key and then use it for win10. i think it still works and you cooul potentially save money.
https://linustechtips.com/topic/1340392-advice-for-a-build/#findComment-14751185
