yes, like @Grabhanem said, when idle you're not supposed to hit max frequency. Try loading it up with sth heavy and if it doesn't hit max frequency at 100% utilization then you can proceed to investigate, if it does - everything's normal.
P.S. afaik AVX-512 instruction set extension runs at sub-nominal frequency, so try loading it up with sth basic at first (CPU Stress Test - An online tool to test your CPU stability | CPU Expert (cpux.net)  - like this thing - just set it to the number of threads you have, power at max and hit run)
https://linustechtips.com/topic/1340248-cpu-speed-capped/#findComment-14749935
