A managed switch allows you to manage the switch config at a different layers of the network stack.
Normally to edit vlans is why you would want a managed switch.
Yes you can modify other things like
- port speed (troubleshoot connection speed issues better, or adjust if needed)
- a mirrored port to dump all the data passing on a switch for analysis,
- agregate ports together, so use two ports at the same time for more speed/reduncancy.
- POE (if you need it)
So for the most part a maanged switch allows more customization options. And in most cases is normally a little faster since they normaally have more memory.
Unless you want to learn about networking on layer 2/3 go with a normal dummy siwtch and you will be fine.
For most home applications you don't need a managed switch. If you just need more network connections then get an unmanaged switch with however many ports you need.
They allow for more network customization than you can do without having one, and they can also be useful for situations where you need to separate network devices from each other logically.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
