I am using a TCL 43" 4k TV as a monitor.
I don't see any issues with the screen as such. I have done dead pixel test and that is also fine. But when I try to move a window to the top, I notice a weird pixel line for a brief second.
See attached video. My return window is still open. Do you think it's an issue with TV panel and I should replace it or this might be because of PC or HDMI cable?
There is only one scenario when I see this issue, otherwise the Pixels in that area are completing fine
https://linustechtips.com/topic/1339422-weird-pixels-on-top/
White box white lines. Is it always white if the box you test with is another color?
https://linustechtips.com/topic/1339422-weird-pixels-on-top/#findComment-14743595
10 minutes ago, Shobhit Bhardwaj said:
if you notice clearly the glitch showing up is not white. It is more like broken pixel line with multiple colors.
So not white lines.  Well that’s my idea down.
https://linustechtips.com/topic/1339422-weird-pixels-on-top/#findComment-14743621
