Hi! I recently found out that V1 Tech, a company known for making GPU backplates and fan grills, are selling the Lian Li Strimer 24 pin Plus for a reasonable price on their website.
Link:
https://www.v1tech.com/shop/cables/lian-li-strimer-plus-24-pin-addressable-rgb-power-extension-cable-20cm-7-87/
I know that V1tech is a pretty well known company for making their own backplates, but I have never seen them sell anything that they do not make themselves. Do you think that Its safe to buy the Strimer cable from there, as I cant find it anywhere for a reasonable price or from a retailer I trust.
Thanks for your recommendations!
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1339278-v1-tech/
They're really well respected and well known, so personally I'd be comfortable with it.
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1339278-v1-tech/#findComment-14742341
Link:
That's a product made by Lian li so they are just a reseller or distributor for them. As for V1 I've recommended them around here for custom work before not heard anything negative back from any around here that I've seen at least.
https://linustechtips.com/topic/1339278-v1-tech/#findComment-14746976
