White liquid cooler
Go to solution Solved by Stahlmann,
3 hours ago, jacobi_nolini said:
with a full atx board?
You should watch this; hes doing basically exactly what you plan to do:
Budget (including currency): N/A USD
Country: united states
Games, programs or workloads that it will be used for: warzone, cold war, cs go, minecraft
https://pcpartpicker.com/list/Ttz3Jf
i am trying to find a reliable white AIO liquid cooler for this build. i have the DEEPCOOL castle in the list right now. is this a reccomended/safe choice? will it have good cooling? any better options that will match a white o11D mini?
https://linustechtips.com/topic/1339181-white-liquid-cooler/
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($550.00)
CPU Cooler: Deepcool CASTLE 360EX WHITE 64.4 CFM Liquid CPU Cooler  ($149.99 @ Amazon)
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard  ($162.99 @ Newegg)
Memory: Team T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($179.99 @ Newegg)
Storage: Sabrent Rocket 4.0 1 TB M.2-2280 NVME Solid State Drive  ($159.97 @ Amazon)
Storage: Seagate IronWolf Pro 4 TB 3.5" 7200RPM Internal Hard Drive  ($139.99 @ Adorama)
Video Card: NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card  ($550.00)
Case: Lian Li O11 Dynamic Mini ATX Mid Tower Case  ($110.00)
Power Supply: Cooler Master V SFX Gold 650 W 80+ Gold Certified Fully Modular SFX Power Supply  ($124.99 @ Amazon)
Monitor: LG 27GN750-B 27.0" 1920x1080 240 Hz Monitor  ($346.99 @ Adorama)
Total: $2474.91
Generated by PCPartPicker 2021-05-18 08:25 EDT-0400
geometry is hard
b550 > x570
https://linustechtips.com/topic/1339181-white-liquid-cooler/#findComment-14741480
Total: $2474.91
I agree get ryzen 5000 instead
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1339181-white-liquid-cooler/#findComment-14741487
40 minutes ago, jacobi_nolini said:
Will the Lian Li Galahad fit?
Depends where you want to put it.
Afaik you can fit 360mm AiOs in the top and bottom.
Up to 280mm AiOs will fit on the side.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1339181-white-liquid-cooler/#findComment-14741664
https://linustechtips.com/topic/1339181-white-liquid-cooler/#findComment-14742475
