So i've been getting this fun little BSOD for around over a month. This BSOD only happens though when I start up certain games such as minecraft and plants vs zombies garden warfare2. I've tried almost everything and I cant figure out why this is happening and how to fix it.
Specs:
I9-9900K
3080 RTX
32GB RAM (might be the cause of the BSOD as I got it around christmas but i only recently started happening.)
SSD/Hard drives: samsung 970 evo plus, samsung 860 evo, and just some old ass hard drive thats around 5 years old which i store the games on usually. Tried putting the game on another drive just to get the same results.
850w PSU
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/
what speed is it running at?
4x8? 2x16?
from my experience, that error code usually has to do with unstable cpu or RAM
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737076
4x8? 2x16?
ive been running my cpu at 5Ghz for months with no error. With my ram ive been running it a a normally stable 3600mhz. For the ram I used the XMP from the motherboard to overclock it,
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737082
850w PSU
So depending on what specific power supply you're running a possible reason is your GPU is causing some sort of voltage drop.
I would try running your ram at stock settings instead of xmp just to see if it is causing your instability
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737083
I will try that right now. I sure hope its nothing to do with my 3080.
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737088
did u go from 2x8 to 4x8?
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737089
Well, if it isn't XMP my next suggestion is DDU, after that looking up other suggestions online it seems like doing a chkdsk /r and sfc /scannow through administrator power shell might be worth trying. I expect you've already run a game file verification check on the problem games
edit: my understanding is sfc checks windows file integrity or something
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737114
after turning off XMP i was able to load plants vs zombies garden warfare 2 without fail. Soon after I was excited and wanted to load into a multiplayer match, While loading into my match i got another blue screen PAGE_FAULT_IN_NONPAGED_AREA
been trying to fix this for the past two hours like wth
https://linustechtips.com/topic/1338604-irql_not_equal_or_less/#findComment-14737309
