A headscratcher. Keyboard problem
Solved by kelvinhall05,
5 minutes ago, letmewearurskin said:Yeah, I figured. But as I said it's expensive, so I wanted to be sure it's the only option before I commit to buying one. Thank you tho.
And I understand it's expensive. But seriously, it's your only option. I'm guessing your sister spilled something on it or set something very heavy on the keyboard (water damage is more likely imo) and the only way to fix it would be to take it apart to the point where you can access both membranes and clean them, then reassemble and hope everything works. It's likely rivited shut and impossible to open, and reassembling would also suck.
