hi i´m having a problem mounting my new motherboard  aorus ultra x570 into my fractal define r5 case..
when i place the motherboard into the central pivot, the rest of screw holes are not aligned... they are 2mm away of the right position
i think the only way is to remove this central pivot...
can i do that without damage the motherboard?
thanks
https://linustechtips.com/topic/1338236-i-need-some-help-please/
