Probably not worth it. Unless you really need those other 2 cores (probably not if you're using NVENC) or if you are noticing a CPU bottleneck where the GPU doesn't go above 80% usage (probably not with a 3060), just stick with the 3600 and save for the next upgrade
https://linustechtips.com/topic/1337737-please-help/#findComment-14730550
appreciate the response, helped out so much.. ill just stick with what I got if its not going to at least give me a 40-50% performance boost
so you recommend streaming from NVENC instead (use obs normally) and sticking with what i got? I would love at least a 40% performance boost but if thats not possible, not worth wasting my money.. btw appreciate the response, so helpful! thank you
https://linustechtips.com/topic/1337737-please-help/#findComment-14730563
NVENC is just an encoder than OBS can use. It basically just redirects the encoding to the GPU with a very low encoder overhead. If you swapped over to a 3700x and did CPU encoding, you might see a 2-3% increase, but that's at best and I would not spend somewhere around $100 on an upgrade for 2-3% increases in performance only while streaming.
https://linustechtips.com/topic/1337737-please-help/#findComment-14730622
