Okay so lately on my ps2 emulator and on Arma, I have been losing fps. after about a week of mild research, I decided to open up 25 taps of the search I did on google. Found out what the problem could potentially. While running games my CPU usage on Task Manager is around 8%. So I guess my CPU is not being used or something. Is there a way to fix this without over clocking, because I don't think My board or my CPU fan could take that.
Gaming Rig "Project Primitus" - AMD FX-8320 CPU, Asus M5A97 R2.0 Mobo, G.Skill Sniper Series 8GB RAM @1866 MHz, WD Caviar Blue 1TB, Gigabyte Geforce GTX 760 GPU, Fractal Design Define R4 Window, Corsair CX600 PSU
Pics and my reviews for the build here - http://pcpartpicker.com/b/LvN
Peripherals - Corsair Vengeance K70 MX Red, Logitech G402,Kingston HyperX Cloud, 21" TV, Steelseries QcK Heavy Mousepad, Macbook Pro 2012 13"
https://linustechtips.com/topic/133727-potential-fix/
is it a heat issue? it might be throttling itself. Have you checked your temps?
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779605
Its probably GPU Boost underclocking your card, how are your temps?
Muh rig: i7 4770k, Cooler Master Hyper 212 Evo, MSI Z87 G45, Kingston Hyper X Blu 8GB, Samsung 840 EVO 120 + WD Blue 1 TB, Asus GTX 770 2GB, Corsair 200r + 2x Corsair AF 120 Blue + 1x Stock corsair fan, Corsair TX650, LG 27EA33V IPS, Steelseries Sensei Raw + QCK mini, CM Quickfire Ultimate Blue.
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779621
Temps seem normal. Using the stock AMD at getting around 38 C which is about what I've been getting since day 1
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779623
Not my GPU, my CPU
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779628
BTW it used to be working fine and (even though I didn't monitor it) it seemed to be under load, the CPU fan ramping up in RPM, and the game giving me good FPS, but it changed a week ago to giving me shit fps and not using my CPU (I guess it all changed when the fire nation attacked)
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779634
Check your open programs something may be running in the background also for the PS2 emulator I assume you are using PCSX2... sorry mate but its unstable and buggy as hell if the games even work there is going to be performance issues.
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779736
its not only PCSX2 its also arms... Also when I play Metro LL it says 8% but I still get like 80 fps
https://linustechtips.com/topic/133727-potential-fix/#findComment-1779786
