Hey guys, I was wondering if I could get some help. I have an Acer aspire laptop that was running windows 10. one morning I switched it on, the windows logo showed but it wouldn't let me login it said lockescreen.exe has failed. I have tried to reset the computer but it always fails and says "there was a problem with this pc could not reset windows" and it doesn't let me us the system recover option either. I'm stuck and need help. so if you can help me kindly do.
P.s first time here so I hope i chose the right sub-thread.
wishing everyone keeps safe and good health
https://linustechtips.com/topic/1336860-help-needed/
Do you have access to another computer? Any files on the laptop you need to get off? I would suggest a clean install but there are a few steps you need to do before that, especially if you want to keep your stuff.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1336860-help-needed/#findComment-14723430
