I am currently in the process of using ATIFlash to unbrick a XFX Radeon RX 570 GPU. Though I have a working MSI ARMOR OC 4GV RX570 being used as well. They are both plugged and powered. The bricked card also has no display coming through it, hence why I have another plugged in with it. I do not have any discrete or integrated graphics. Though I would like to fix the XFX, I really don't want any risk of accidentally screwing up my good card. I've already got the BIOS rom file downloaded. I just need a walkthrough to flash it. This is what is showing up on ATIFlash when I start it up:
The cards being used:
Main
Bricked
Motherboard: Link
I have my main card plugged into the PCIe X16 4.0 slot, and the Bricked in the PCIe X16 3.0 slot. If any of that info helps.
https://linustechtips.com/topic/1336662-atiflash-help/
ok so on the top it shows you the cards you have plugged in, there should be another one bellow that 0x67df card, using something like gpuz find out which card is which, by looking at which card has which bios name, then you want to choose the right card on the list then click load image to load the bios you want to flash, finally press program to program that bios into your gpu
https://linustechtips.com/topic/1336662-atiflash-help/#findComment-14721974
