CPU Watercooling Kit
Go to solution Solved by Izaya Orihara,
There is no specific retailer that I will be buying from. I am able to easily find the majority of my selected parts locally but as for water cooling kits and other water cooling parts, there is little information provided by local retailers, so I will probably be buying the watercooling system online if it is not locally available
I kinda needed the info to make a build since well you will probably have awful pricing. But here is a 2000$ US build PCPartPicker part list: http://pcpartpicker.com/p/3j4dp
Price breakdown by merchant: http://pcpartpicker.com/p/3j4dp/by_merchant/
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($319.99 @ Newegg)
CPU Cooler: Be Quiet Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler  ($89.99 @ NCIX US)
Motherboard: MSI Z87-GD65 Gaming ATX LGA1150 Motherboard  ($167.99 @ NCIX US)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory  ($124.99 @ Amazon)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Disk  ($260.98 @ Newegg)
Storage: Western Digital Green 4TB 3.5" 5900RPM Internal Hard Drive  ($161.99 @ Amazon)
Video Card: MSI GeForce GTX 780 Ti 3GB Video Card  ($659.99 @ Newegg)
Case: NZXT H440 (Red/Black) ATX Mid Tower Case  ($119.78 @ Amazon)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Amazon)
Total: $2025.69
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-30 12:24 EDT-0400)
I'm looking to build a PC with a i5-4670k CPU, MSI Z87-GD65 mobo, Asus GeForce GTX 780 GPU. I intend to air cool the PC except for the CPU, which I would like to watercool. Anybody have recommendations for a watercooling kit which is of a good quality, at a reasonable price (Prefably fitting the red theme of the PC)? And perhaps some help choosing an adequate power supply which would support the watercooling kit as well as the other parts. Need help as this is the first PC I am building and am rather new at this.
https://linustechtips.com/topic/133542-cpu-watercooling-kit/
Buy an AIO. There should be no need to factor in power consumption of water cooling unless you're doing something beyond exotic.
Water cooling CPU only is pretty pointless, especially if, figuratively, you have no idea if your chip even lifts
Avoid water cooling kits like the plague, 80% of them suck. If you're going to do water cooling don't half ass it, do it right. Full loop, good parts, or stick with air or AIO. I would also advise against doing water cooling on your first build.
Error: 410
https://linustechtips.com/topic/133542-cpu-watercooling-kit/#findComment-1776973
Link to the retailer you sill be buying the stuff from?
https://linustechtips.com/topic/133542-cpu-watercooling-kit/#findComment-1777085
Total: $2025.69
https://linustechtips.com/topic/133542-cpu-watercooling-kit/#findComment-1777112
