Need advice on what would be best to upgrade.
Solved by Moonzy,
2 minutes ago, Lolply said:The only thing i really feel is lacking is my screen, i would like to have coulors that arent as dull. And one that can use hdmi.
Then that's your next upgrade then
There's a ton of decently priced 1080p144hz IPS panels out there nowadays
You may also consider 1440p but you may need a GPU upgrade to push that resolution well
