Will my gpu fit?
Go to solution Solved by SPARTAN VI,
9 minutes ago, ant0n742 said:
Yea that was my concern. Do you think it will fit if I go with a mini-itx PSU or should I just return the case?
Unless that case's PSU shroud/basement can be removed, then I don't think it will fit regardless of what PSU you put in there (or not). If you haven't already opened the case, you should probably exchange it for one that can accept a thicker GPU. For a similar ITX footprint, my suggestion would be to look into the new Phanteks Eclipse P200A line
If I've answered your question, please hit the "mark as solution" button on my post to show that this issue has been resolved:
Thanks!
I really need help. I have just received both my gpu and my case but I don’t know if the gpu will fit (I don’t want to unpack the case in case I have to return it). The gpu I ordered was the DUAL-RTX2060-O6G-EVO and the case is the NZXT 210i. I can’t figure it out and would really appreciate if anyone could help.
https://linustechtips.com/topic/1335301-will-my-gpu-fit/
According to NZXT's Website: https://www.nzxt.com/products/h210i-matte-black
GPU Clearance: Up to 325mm
According to ASUS's Website: https://www.asus.com/us/Motherboards-Components/Graphics-Cards/All-series/DUAL-RTX2060-O6G-EVO/techspec/
Dimensions
9.53 " x 5.12 " x 2.09 " Inch
24.2 x 13 x 5.3 Centimeter
24.2 Centimeters = 242 mm
So yes, the card will fit.
https://linustechtips.com/topic/1335301-will-my-gpu-fit/#findComment-14711858
Dimensions
I think his concern is the fact that his RTX 2060 SKU is 53mm thick (2.5 slots) while the case only supports up to 44mm. It wont fit because the PSU shroud is in the way.
H210i case specs:
RTX 2060 Dual EVO specs:
https://linustechtips.com/topic/1335301-will-my-gpu-fit/#findComment-14711865
H210i case specs:
https://linustechtips.com/topic/1335301-will-my-gpu-fit/#findComment-14711899
Thanks!
https://linustechtips.com/topic/1335301-will-my-gpu-fit/#findComment-14711915
