6 minutes ago, TheDarkWizard said:
Okay thanks! any recs? I was thinking x570 tomahawk maybe
Tomahawk is a great choice. Really solid power delivery and solid IO. if you have plans to add on more gen4 ssds then you'll definitely want to go x570 over b550.
Yes, okay awesome, I'll go with the tomahawk then instead of the aorus master.
