Depends on where you live and if you what something that can be moved about so you can turn it if you need it, you're best bet is to go in to your local electronics store that sells TV's and ask what they have for a 27" TV its not going to be cheap but then again you don't what a 27" monitor falling of the wall.
The other thing you could look at is get a monitor arm that is clamped on the desk.
Cry Havoc!
https://linustechtips.com/topic/133470-wall-mount-vesa-help/#findComment-1780539
