Is there a program to allow a dual monitor wallpaper to go across two different sized monitors?
Solved by Glenwing,
37 minutes ago, TSSMB said:I am aware that the span image works with same sized monitors but with two different sizes, it makes the scaling really poor. It leaves area on the left of the left monitor and on all sides of the right monitor. It also doesn't split the wallpaper right in the middle, it should split around the right side of the "1".
Go the "adjustments" tab and see if anything there helps.
