If you right click the application icon, doesnt pop up in the list of actions something like: "Open with graphics processor" with a drop-down list with two options?
CPU: Ryzen 5 3600 @ 4.4GHz 1.2v / GPU: MSI Radeon RX 5700 Mech OC GP (5700XT Bios) @ 2GHz / MB: Asus ROG Strix B450-F / RAM: Kingston HyperX 16GB DDR4 3200MHz CL16 / CASE: MSI MAG Vampiric 010X
That's for the Java edition launcher. Look for something like 1.16.<something> or a snapshot number.
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
on the nvidia side of things, it only ever works reliably if you just set the dGPU as primary.
few things you can try:
- set java.exe and javaw.exe executables (found in the java install directory) to use dGPU
- set minecraft.jar (inside the minecraft install directory) to use the dGPU if the AMD side of things allows you to do that.
- set the launcher executable to use the dGPU.
Just now, LeONardoo said:
its 1.16.5
So look for Minecraft: 1.16.5 with the crafting table, and dedicate it to that, or the JRE Runtime Environment. I play on Bedrock so I could be wrong
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
java is incredibly terrible with the gpu switching thing, the best bet is to essentially go trough every executable in the chain and hope at some point the setting will stick.
7 minutes ago, LeONardoo said:
Look in ./runtime?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
