Need help with watercooling
I want to build my first PC soon and then add custom Hydro X loop to it. I noticed, however, that motherboard I've chosen has no w_pump connector, but has an AIO_pump connector.
Can I use that second connector for powering a pump and reservoir combo?
Motherboard: ROG Strix B550A
Pump: Hydro X series XD5 RGB pump and reservoir combo white
The Corsair XD5 pump uses a 4-pin molex for power connection (like most D5 pumps).
