Hi everyone, i need help on upgrading or selling my current pc and build a new one
Budget: 100 USD (for upgrading)
Country: Indonesia
Games, programs or workloads that it will be used for: Valorant, Kerbal Space Program (modded), Fortnite, GTA V and light editing
So currently my system has a H110MK mobo i7-6700 16 GB of ddr4 ram and GT 1030 also 2 SSDs and 1 HDD
My budget for upgrading is around 100 USD or in my currency 2.000.000 Rupiah
I dont really know what to do so i come here to ask you guys for upgrading i prob only get a gtx 1660s
Best bet would be looking on your local markets, could probably snipe a 1660 like you said or maybe even a 2060. CPU upgrade won't give you much difference at all
Console.WriteLine("Hello World!");
A GTX 1660 super is a good purchase for this PC, it is an appropriate pairing for an i7-6700
Primary PC:
What psu do you have? Psu make and model please. Depending on that we can see a course of action. A gpu upgrade here will go a VERY LONG WAY but if your psu cant handle it then that needs attention first.
a 2060 in my country is around like 200 usd should i buy used ones or no?
7 minutes ago, cornislife said:
I currently have a  235 watt armageddon PSU idk what brand is that i think is a local brand
I just looked it up, I see the "Armageddon Voltron Bronze" as the first result. Is this what you have?
It looks really bad, not sure I would trust it to power a decent graphics card. And 235 watts is a really low amount, I'm not sure it would work.
Primary PC:
Oh nevermind, that'll need swapping too then.
Yes that what i have.
So i would need to save up more for a psu also? and which one should i buy for a good price
Do you have a "normal" pc case or is it from a prebuilt company like Dell / HP?
14 minutes ago, cornislife said:
Yes i have a normal case not a dell or hp case
You can just pick up any ATX psu you need then, maybe around 500w for your needs.
I'm not as familiar with Indonesian pricing and what's available on the market. In general, is an 80+ bronze 400 to 500 watt power supply something that you could afford?
Primary PC:
