Hello, can someone help me? For the past 2 weeks I've been having fps issue with this system.  The system is a mix and match of old parts from my brother's pc
PC Spec
CPU: Core i5-6600 (used)
GPU: ZOTAC GTX 1060 3GB (used)
MOBO: Biostar H110Mhv3 (used)
RAM: 12GB DDR3 1600MHZ (8gb+4gb lol) (Dual Channel) (New)
PSU: CM  MasterWatt Lite 600W (New)
The monitor that I used is a LG with a resolution of 1440x900 (used a vga to dvi adapter to connect the monitor lol) .
(The screenshot was taken from a bot match)
When playing dota2 in intensive part, the gpu usage is around 25% to 35% at 1596MHZ core clock, while the cpu clocked at 3.5GHZ at 80% to 95% usage with 44fps.
The setting that i use
While at the menu, the gpu usage is higher at 55% to 75% usage at 1569MHZ core clock, while the cpu is at 40% to 50% usage and clocked at 3.7GHZ with 100+fps.
Can someone explain and come up with a solution, or is the gpu is beyond repairable?
Thank you.
Things that i've tried so far (but the problem still occurs):
  • Trying to play with a stick of ram
  • Change the setting across all setting (low to high)
  • reinstalling nvidia drivers
Note:
  • I tried running various api (dx9, dx11, vulkan, and opengl) but the result is still the same. i'm also using the latest nvidia drivers and on the latest mobo bios.
  • The weird part is, in some games eg Titanfall 2 played at the recommended setting can easily reach 80+fps, apex legends played at mix of medium and high around 70+fps (a bit stuttering) with a gpu usage above 50%+.
https://linustechtips.com/topic/1333669-low-fps-with-this-system/
You're CPU bottlenecked, especially at such a low resolution.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
