Hi there,
i had a nasty BSOD today while playing Desperados 3. PC freezes completely while having a weired image on Display and then it restarted by itselfe. I have a new System and i want to be sure its not some critical hardware fault. Mini-Dumps are attached.
My Drivers are up to date. (GPU/BIOS/Chipset/Windows Update)
Also i tested my Ram with Memtest86 2-3 weeks ago with zero Errors by 4 passes.
Temps are fine -> 72 cels CPU and 70-80 cels for GPU while under load.
Please Help 馃槥
My Specs:
Win10
B 550-A Pro
RTX 3080
Ryzen 5800x
32 GB crucial Ballistics
Corsair RMx 750w ATX 2.4
Thank you very much in advance!
031821-5828-01.dmp 043021-5796-01.dmp
https://linustechtips.com/topic/1333015-bsod-while-gaming-pls-help/
Ok, I'm going to post the relevant parts of the crash, then I'll post my thoughts below that.
___
MEMORY_MANAGEMENT (1a)
聽 聽 # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000000403, The subtype of the bugcheck.
Arg2: fffff9810c30eea0
Arg3: 810000000002a0e5
Arg4: fffff98000000000
CUSTOMER_CRASH_COUNT: 聽1
PROCESS_NAME: 聽GTA5.exe
IMAGE_NAME: 聽memory_corruption
___
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8071d7fd212, Address of the instruction which caused the bugcheck
Arg3: ffffd301b1d8f920, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
PROCESS_NAME: 聽Desperados III.exe
___
Ok, possibly bad RAM (or a bad XMP/OCing profile)
Turn OFF XMP and and OCing you have done
Test your RAM with MmeTest86 (note, this will take some hours)
Report back your findings.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.聽
Thank you for your respons!
I have allready tested my new RAM with Memtest86 some weeks ago. No errors there.
So is there an argument for RAM fault in the latest BSOD from today (Process_name Desperados III.exe) too?
I changed Ram a while ago and im not sure if the older BSOD was with my old ram. Please advise for the BSOD from today. (once more attached)
Thank you very much.
043021-5796-01.dmp
