Budget (including currency): not relevant but 90€-180€
Country: Portugal (hey!)
Games, programs or workloads that it will be used for: after effects, blender, c4d, premiere, games like Cod, gta v rp, lol, valorant.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): my current build is this one https://pcpartpicker.com/list/V3Tzrr   minus the power supply cause it doesn't matter in picking a case I think.
Bottom line is, I'm looking into the lianli lancool 2 mesh rgb. I'm not sure if that's optimal for air-cooling and cable management or if there is another better option, like is the lianli lancool 215 better or it has some drawbacks? Am I making a good choice with the lancool 2 mesh rgb or not really ?
Thanks!
https://linustechtips.com/topic/1332865-case-swap-options/
