Ok so I bought a sound bar it's a Vizio the model is in the pic below (SB3241N). What I'm wanting to do is hook the sound bar through ARC coming out of my TV, the issue though is I only have 2 HDMI ports on the TV, and I have my Xbox One S and my PC that I hook up to the TV. My question is there a device that will combine 2 HDMI's down to one plug on the TV. Next question is there another device that will take my toslink coming out of the PC and the one coming out of my TV that goes into a single toslink port on the sound bar?? I will clarify anything if I wasn't clear and I can provide pics as well if you need them, thanks.
Thomas
MSI Z490 CARBON FIBER  | i9-10850K@5.2Ghz @1.212v | ASRock OC Formula RX6900XT 16GB | 32GB G-Skill Trident RGB 3200Mhz | Custom CPU and GPU Loop(EKWB, Bykski, Primochill) | EVGA Supernova P3 1200W | 2x 250GB Samsung 980 RAID-0 | 2x 500GB Samsung 870 EVO RAID-0 | 1x 2TB Seagate Barracuda 7200RPM | Phanteks Enthoo Pro2 | 8x CM Sickle Flow 120mm Fans | Windows 11 64 Bit
https://linustechtips.com/topic/1332524-help-with-arc-soundbar/
Oh and currently I have the toslink coming out of my TV that goes to the soundbar for sound. And because I have PC and Xbox hooked up through HDMI when I go to that input the sound goes through the HDMI's and then through the toslink into the sound bar that then gets played through the soundbar also.
Thomas
https://linustechtips.com/topic/1332524-help-with-arc-soundbar/#findComment-14691929
BUMP.
Thomas
https://linustechtips.com/topic/1332524-help-with-arc-soundbar/#findComment-14694263
Can anyone help me please??
Thomas
https://linustechtips.com/topic/1332524-help-with-arc-soundbar/#findComment-14699255
