Budget (including currency): 2000
Country: US
Games, programs or workloads that it will be used for: Gaming and school, will be used for years
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have a grapics card i will use until they are affordibe. Also where can i save some money? Anything helps
https://linustechtips.com/topic/1332517-pc-part-picker-list-help/
Motherboard and power supply are both way overkill. Something like the Gigabyte B550 AORUS PRO AC will give you the same performance in overclocking, for half the price. For PSU, what GPU were you planning to get down the line? I'd probably recommend something like the Corsair RMx 650W/750W.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Country: US
do you have a gpu? because you may need to save more money on like a rtx 3080 later on
Trident Z modules are a sub-optimal pairing with the NH-D15.
The psu has far more capacity than needed.
Cut out all the bling.
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($444.00 @ Newegg)
CPU Cooler: Noctua NH-U12A 60.09 CFM CPU Cooler  ($109.95 @ Amazon)
Motherboard: MSI MEG B550 UNIFY ATX AM4 Motherboard  ($288.39 @ B&H)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($187.99 @ B&H)
Storage: Samsung 980 Pro 2 TB M.2-2280 NVME Solid State Drive  ($349.99 @ B&H)
Case: Fractal Design Meshify 2 Compact TG Dark Tint ATX Mid Tower Case  ($119.98 @ Newegg)
Power Supply: SeaSonic FOCUS 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.99 @ B&H)
Total: $1650.29
Generated by PCPartPicker 2021-04-28 21:40 EDT-0400
