I bought a Ryzen 3 3200G along with other parts for a simple PC for my father. It wont post, I know I need to update the motherboard bios. I also have an old AMD A4-6300 APU, can I update my bios with that CPU or should I contact AMD for the boot kit?
Here is the list https://pcpartpicker.com/list/YQHDy4
https://linustechtips.com/topic/1332511-pc-wont-post/
Completely different socket, you cant use that to boot the BIOS. Go and contact AMD or your retailer for a Boot Kit.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1332511-pc-wont-post/#findComment-14691860
