As @Radium_Angelsaid liquid nitrogen
if you're being practical then custom water cooling
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691246
Just now, Damian Gonzalez said:
Funny but serious answer
You didn't specify any details of what you wanted. All you said was "best" so I gave you best.
You want Air? AIO? Custom loop?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691252
It is the best. You never said what you want so he gave you the best. Serious enough.
Big nerd.
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691255
air or aio
how much money do you plan on spending, what country
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691259
200$ US Max
I'd say the NH D15 from Noctua, its basically as good as any AIO for cheaper. And you don't hafta worry about failure
Big nerd.
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691264
200$ US Max
any of thhe huge 360mm of 420mm radiators are pretty effective at cooling, if you have a case that's massive enough to fit one
Primary PC:
PSU tier list
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691269
Air cooler:
NH-D15. It performs like a 240mm aio for a better price than most and basically 0 maintenance. If you don't want any fuss and just want good cooling you should get this one.
Liquid cooler:
I would say the Kraken x73 is one of the better 360mm aios, but you might be better off just getting a D-15 and spending your money elsewhere in the system if you don't have a specific need for a lot of cooling like overclock. https://www.amazon.com/NZXT-Kraken-X73-360mm-RL-KRX73-01/dp/B082DYKB1F/?tag=thowisguy-20
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14691328
D15 if you're needing something that's easy to install and affordable as well as being a reliable and practical solution. Good ol' Noctua.
360mm AIO if you want marginally better performance or you want some RGB aesthetics. No real advantage to an AIO over classic air coolers. You could consider the Intel Cryo Cooler as that is sub-ambient cooling for something in the form-factor and size of an AIO.
Custom water cooling if you want the absolute best cooling while still being practical.
Liquid nitrogen for the extremes, although I can't imagine a scenario where this may be useful other than XOC.
https://linustechtips.com/topic/1332451-best-cpu-cooler/#findComment-14692241
