3 minutes ago, Meatball the man said:
Do 80mm aio exsist for lga  1200
I've never heard of one, but it would be pointless if they did. Even 120mm is not good enough for cooling, but is sometimes the best you can do in smaller ITX cases.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1332348-question/#findComment-14690292
Make sure to quote or mention (@PorkishPig) the person you're replying to.
5 minutes ago, Meatball the man said:
what about a air cooler
What are you looking for, specifically?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1332348-question/#findComment-14690341
1 minute ago, Meatball the man said:
something to handle a i5 11400f at nice temps the height dosent matter really
Do you need a low profile cooler? What was the reason for needing a 80mm AIO?
You don't need anything fancy for the 11400f, just grab a 212 EVO Black.
Desktop
Homelab
https://linustechtips.com/topic/1332348-question/#findComment-14690375
the reason is that im being stoborn and i want to use the optiplex case (dw its the tower varient (the one thats all itx))
https://linustechtips.com/topic/1332348-question/#findComment-14690380
80mm tall? Downdrafts maybe, i.e. the fan faces the motherboard.
Desktop benching:
https://linustechtips.com/topic/1332348-question/#findComment-14690511
Noctua L12S is 70mm tall and keeps up with my 5800x.
https://noctua.at/en/nh-l12s/specification
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1332348-question/#findComment-14690577
