2 minutes ago, jgminer15 said:
Im looking for a motherboard that works for phanteks Eclipse P350X pc case.
It must support AM4 and it has to be EATX if not size down if nothing size down again and so forth.
MSI MAG B550 Tomahawk Gaming comes with addresable rgb header and its b550 mobo.
https://linustechtips.com/topic/1332245-rgb-case-help/#findComment-14689544
3 minutes ago, jgminer15 said:
im not a pc expert but looking on the words inscribed on it, i dont see argb or anything close to that
check this => https://www.amazon.com/MSI-MAG-B550-TOMAHAWK-Motherboard/dp/B089CWDHFZ/ref=sr_1_2?dchild=1&keywords=MSI+MAG+B550+Tomahawk+Gaming&qid=1619604163&sr=8-2 see in the about this item you will see about the rgb headers
https://linustechtips.com/topic/1332245-rgb-case-help/#findComment-14689562
Just now, Crafter King said:
yea i was just looking at that
https://linustechtips.com/topic/1332245-rgb-case-help/#findComment-14689564
