Hey guys I just finished buildin my first pc and am about to start doing drivers and such. The only problem is I don't have a CD drive to use the disc that came with my mobo ( Gigabyte GA-z77x-ud5h) and my Ethernet controllers are not working because I do not have the drivers. is there anyway to install drivers from a usb like i did with windows?
https://linustechtips.com/topic/13322-first-build-need-drivers-help/
Keep in mind that you will also need some unzip utility, Look for 7zip
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
Download the drivers on a USB from an other computer, but do not open them otherwise they will install on that computer. Plug the USB in and open the drivers. You should then be able to follow the instructions that come up when you install programs. The best way is to not change where the drivers will be installed. They will always be installed on the C drive or the main windows drive.
Asus Sabertooth Z77, Intel 3770K 4.6GHz @ 1.33V, EVGA GTX670, Corsair Vengeance 16GB RAM, and Corsair 800D
