Help Finding a Cable
Go to solution Solved by RedFlameDragon,
managed to find one,
https://www.moddiy.com/products/USB-3.1-Gen-2-Internal-Type-E-Front-Panel-Header-Extension-Cable.html?setCurrencyId=4
pretty much the only one i've ever seen on the internet.
So I built a new computer, into a desk I had made. I had gotten one of those disk drive front I/O bits to use as my usb/audio ports, but I hadn't fully accounted for how far from the MOBO it was. so i need some form of extender cable for the usb type C and usb 3.0 cables it has, as those can't reach the mobo. i tried poking around on amazon and such, but i can't seem to find the right cable
https://linustechtips.com/topic/1332113-help-finding-a-cable/
3 minutes ago, RedFlameDragon said:
this is a pesimistic way to look at it, but do you use your USB front IO?
Id check cablemod or if you feel up to it, try making your own.
Main PC: the literature club machine
Intel I5 9600k @ 4.2 Ghz | MSI z390-a pro | G.Skill Trident Z RGB 32 GB 3000Mhz | Samsung 970 1TB | 2x Seagate barracuda 3.5" 2.5tb  | Thermaltake Floe Riing RGB 240 | MSI Ventus 2x black RTX 4060 TI 8gb | Be Quiet Pure Base 500DX
Daily drivers
Apple Iphone 12 | Apple Macbook Pro 2020 16gb | Ducky One 2 Skyline | Logitech G pro | Beryodynamic DT 990 PRO | Focusrite Scarlett 2i2 Gen 4
https://linustechtips.com/topic/1332113-help-finding-a-cable/#findComment-14688792
I do plan on using that front I/O for my phone and such, specifically the C. the MOBO is built inside the desk, and the top is 1 large piece that's about 170cm x50cm, with only a couple holes in the back for the monitor cables, so it'd be a huge convenience to not have to lift up the entire thing and thread a new cable in any time I need to use something usb.
https://linustechtips.com/topic/1332113-help-finding-a-cable/#findComment-14688813
