Budget (R$4.000):
Country: Brazil
AAA games and Programing
Hi all,
Is there any bottlenecks in assembling this parts together?
I already have a Gigabyte GeForce GTX 1050 Ti G1 Gaming and a corsair 600W Gold SPU and a Kingstom 240GB SSD and wanto to upgrade the core parts now, so any advice would be really apreciated.
https://linustechtips.com/topic/1331909-tips-for-parts/
Don't worry about bottlenecks. this is a decent system. However, you can save money with a B450 motherboard if you want, like a B450 Pro-VDH Max, B450M Bazooka Max, or B450M/AC
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1331909-tips-for-parts/#findComment-14687222
hey no bottlenecks.
as he said b450 can save you some money.
I would actually advise going intel if you can find it for the right price, better gaming performance..
11400F paired with some basic B560M mobo like one of these:
asrock b560m-hdv
gigabyte b560m-ds3h
if you plan to overclock you will be limited with intel.
your ram is a solid choice but you mostly can find 3200 CL16 for the same price.
https://linustechtips.com/topic/1331909-tips-for-parts/#findComment-14687384
