Budget (including currency): Not sure yet
Country: United Kingdom
Games, programs or workloads that it will be used for: Music/Audio Workstation
Other details: My current workstation won't work on Windows 10 so need a new system (I bought Windows 10, tried booting which worked, however after being on for 30 second, blue screen of death)
Hello,
My current system is around 7 years old, I bought the parts in 2014 from Scan.co.uk and built it myself.
Spec:
Processor: 2 x Intel® Xeon® Processor E5-2643, 4 Cores, 8 Threads, 10M Cache, 3.30 GHz, 8.00 GT/s Intel® QPI
Motherboard: ASUS Z9PE-D16 Serverboard
RAM: Kingston KVR16R11D4K4/64 64GB (16GB x4) DDR3 1600Mhz ECC Registered Memory RAM DIMM
I am looking at replacing this system with an equivalent. I'm looking at getting a system from Scan.com
I am going with the Custom PC Build "3XS Custom Xeon Scalable"
Processor: ???
Motherboard: ASUS WS C621E SAGE
RAM: 12 x 16GB Samsung M393A2K40CB2-CTD DDR4 Server RAM (192GB RAM)
I am wondering which of these Intel Xeon processors (x2) will give me the equivalent or hopefully slightly better performance than my current system.
2x Intel Xeon Silver 4208, S 3647, Cascade Lake-SP, 8 Core, 16 Threads, 2.1GHz, 3.2GHz Turbo, 11MB Cache, 85W, Retail [£792.91]
2x Intel Xeon Silver 4210, S 3647, Cascade Lake-SP, 10 Core, 20 Threads, 2.2GHz, 3.2GHz Turbo, 13.75MB Cache, 85W, Retail [£961.20]
2x Intel Xeon Silver 4214, S 3647, Cascade Lake-SP, 12 Core, 24 Threads, 2.2GHz, 3.2GHz Turbo, 16.5MB Cache, 85W, Retail [£1,306.34]
2x Intel Xeon Silver 4216, S 3647, Cascade Lake-SP, 16 Core, 32 Threads, 2.1GHz, 3.2GHz Turbo, 22MB Cache, 100W, Retail [£1,679.98]
2x Intel Xeon Gold 5218, S 3647, Cascade Lake-SP, 16 Core, 32 Threads, 2.3GHz, 3.9GHz Turbo, 22MB Cache, 125W, Retail [£2,370.98]
Thank you so much in advanced.
Motherboard ASUS Dual Scalable Xeon WS C621E SAGE EEB Workstation Motherboard
 CPU - Dual Intel 16 Core Xeon Silver 4216 2nd Gen Scalable
 RAM - Samsung Server RAM 192GB 2666 MHz ECC RDIMM DDR4
Storage - 3 x Samsung 970 EVO PLUS 1TB M.2 NVMe SSD   /    6 x Samsung 870 EVO 500GB   /   2 x Samsung 870 EVO 1TB   /   1 x Seagate IronWolf 4TB
OS - Windows 10 for Workstation
Soundcard - RME HDSPe AIO
Graphics - PNY NVIDIA T400 2GB
Case Fractal Design Define 7 XL Black
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/
This may not be because of Windows, it depends on what the BSoD has to say, if you still have the install, find the crash dumps and upload them here, I can pinpoint what's going on.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14678839
Also, any of those Xeons you listed will be fantastic, it's all a matter of if your applications like single core speed, or lots of threads/cores...something only you can answer
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14678844
Thank you for responding.
I contacted ASUS and they said it's because the motherboard will not support windows 10. I reverted back to my Windows 8 Installation so I don't have those files sorry.
Thank you though.
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14678854
Thank you. I was just put off by the clock speed of those silvers vs my old E5's. It's Cubase (Audio Workstation), I think it prefers more cores rather than a focus on speed, but I could be wrong.
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14678857
That's not *entirely* true...all they are saying is they won't support it, not that it doesn't work. But nevermind.
Before spending that kind of dosh, find out, it would suck to buy the wrong thing at that price...
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14678868
Ah okay.
Thank you for your support and time.
Regards.
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14678880
Hey, first i would try to find the reason for the BSOD but if you want to upgrade anyway. Maybe one of these chinese offerings might interest you.
https://de.aliexpress.com/item/4001051807122.html?spm=a2g0x.12010615.8148356.6.73af6d79Xaopt4
The 12 Core Xeon in the Bundle is a huge step up to your current one and the mainboard supports ddr3 and ddr4 so you can keep your current ram. Still you cant mix DDR3 and 4.
I already built a system using the F8 Motherboard and it works great, HUANANZHI is the best Chinese x99 Brand currently. They use refurbisehd intel server chipsets.
I also put one Xeon Silver in a comparison with your current cpu and my suggestions.
https://www.cpubenchmark.net/compare/Intel-Xeon-E5-2678-v3-vs-Intel-Xeon-E5-2643-vs-Intel-Xeon-Silver-4214/2584vs1217vs3535
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14679359
Thanks. the BSOD appears before I get chance to extract any files. Even in safe mode 😞
https://linustechtips.com/topic/1330790-xeon-vs-xeon-help/#findComment-14680547
