Do you want to use it with a separate graphics card or use the integrated graphics?
I would say get the Ryzen 3 3200G, because the Vega 8 is a better integrated gpu.
For the motherboard I think an A520 chipset is fine for Ryzen and it's cheap. It depends on if you need ATX or mATX size too.
Some suggestions:
Gigabyte A520M H (or DS3H or S2H)
Asus Prime A520M-K (or A520M-A or A520M-A II)
MSI A520M-A PRO
More expensive, but with more features:
Gigabyte Aorus A520 Elite
MSI MAG A520M Vector Wifi
