First time build, need help to configure my parts
Budget (including currency): 2000
Country: USA
Games, programs or workloads that it will be used for:  video games, school and just upgrading my pc
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): my list of parts i want to get are here:
Case NZXT H710 Tempered Glass Gaming Case - Matte Black
Case Fans 3x [Silent] be quiet! Silent Wings 3 PWM 120mm Black Fan
Processor AMD Ryzen 7 5800X Processor (8X 3.8GHz/32MB L3 Cache)
Processor Cooling NZXT Kraken X73 360mm ARGB Liquid Cooling System
Memory 16 GB [8 GB X2] DDR4-3600 Memory Module - G.SKILL Trident Z (RGB LED)
Video Card [PREORDER - Extra 6 Weeks Lead Time] NVIDIA GeForce RTX 3060 Ti - 8GB GDDR6 (VR-Ready)
Motherboard ASUS ROG X570 CROSSHAIR VIII HERO (WI-FI) - WiFi 6, ARGB Header (2), USB 3.2 Ports (1 Type-C, 11 Type-A), M.2 Slot (2)
Power Supply 650 Watt - Standard 80 PLUS Gold - Free Upgrade to 750 Watt - HIGH POWER 80 PLUS Gold
what i had was an HP pavilion prebuilt desktop, here are the specs:
PROCESSOR
AMD Ryzen™ 3 4300G (3.8 GHz base clock, up to 4.0 GHz max boost clock, 4 MB L3 cache, 4 cores)
GRAPHICS
Integrated: AMD Radeon™ Graphics
MEMORY
8 GB DDR4-3200 SDRAM (2 x 4 GB)
MAXIMUM MEMORY
Upgradeable to 32 GB
MEMORY SLOTS
2 DIMM
STORAGE
256 GB PCIe® NVMe™ M.2 SSD
SECONDARY STORAGE
1 TB 7200 rpm SATA
(my pavilion has an x570 Ryzen with built in graphics, but the other parts are close to what i had)
also this is on that i've also been debating on getting:
CASE:
NZXT H510i (Black)
MSRP
$99.99
GPU:
NVIDIA GEFORCE RTX™ 3060 - GIGABYTE GAMING OC
MSRP
$549.99
CPU:
AMD Ryzen 7 5800X 8-Core 3.8GHz
MSRP
$449.99
CPU COOLING:
NZXT Kraken X53
MSRP
$129.99
MOTHERBOARD:
MSI MPG X570 GAMING EDGE WIFI
MSRP
$209.99
RAM:
G.SKILL TridentZ RGB 3200MHz (max speed) 16GB (2X8GB)
MSRP
$114.99
SSD:
MSRP
Western Digital SN550 1.0 TB
$104.99
HDD:
MSRP
Seagate Barracuda 2.0 TB
$59.99
POWER:
XPG Core Reactor 750W Gold
MSRP
$139.99
Country: USA
PROCESSOR
GRAPHICS
MEMORY
MAXIMUM MEMORY
MEMORY SLOTS
2 DIMM
STORAGE
SECONDARY STORAGE
1 TB 7200 rpm SATA
Two things, first, both case options that you have listed (NZXT H710 and H510) are terrible cases. Yes, they look good, but they are very poor airflow characteristics. I really don't recommend going with either of them.
Going X570 for the motherboard might be a waste of money unless you need a specific feature that only that chipset can provide. If not, you are much better off with a B550 board.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
what would be a good case on this budget?
Take your pick:
CASE:
NZXT H510i (Black)
MSRP
$99.99
GPU:
MSRP
$549.99
CPU:
MSRP
$449.99
CPU COOLING:
NZXT Kraken X53
MSRP
$129.99
MOTHERBOARD:
MSRP
$209.99
RAM:
MSRP
$114.99
SSD:
MSRP
$104.99
HDD:
MSRP
$59.99
POWER:
MSRP
$139.99
The NZXT cases don't have the best airflow. A case with a mesh front would be better i.e Corsair 4000D/5000D Airflow, Phanteks P400A or Fractal Meshify C etc.
Avoid that board at all costs as the VRM is terrible. The B550 version on the other hand is very good.
