Budget (including currency): $1500 - $2200 USD
Country: USA
Games, programs or workloads that it will be used for: Minecraft, web development (coding with javascript), and video editing
I have been planning on getting a pc for a while, and I finally have the money do get one. I plan on buying it as soon as 2022 (probably 2023ish). It will be my first build, and I would like 2 monitors included in the price. Resolution wise, I would like at least 2560x1440 with a refresh rate of 144hz if possible. I want to be able to play most games at at least 60fps. the higher, the better, if it can fit into my budget. I have four lists thanks to pcpp, and  I need help choosing the best one and/or making a better list.
https://pcpartpicker.com/list/Tghwvf (no monitor)
https://pcpartpicker.com/list/xz7B68 (no monitor)
https://pcpartpicker.com/list/xZzZ3Z (no monitor)
https://pcpartpicker.com/list/sBhQsX (monitors included)
https://linustechtips.com/topic/1330281-first-time-build-i-need-help/
Seeing as you aren't planning to get it anytime soon i would personally hold off  until you are going to make the order. You may find cheaper prices and gpu's in stock at msrp when you are ready. If i had to pick though i like list 2 due to the beefcake 10900k. Ryzen would be best bang for buck providing you can get it in stock.
Rose's are red violets are blue, without computers I'd know not what to do.
2 hours ago, ryan12_07 said:
thank you. should i post again when it is time for me to buy a pc?
ask again 1-2 weeks before you're ready to build.
