I have installed my gpu (3070) into my PC and also switched my power supply (650w)
It has not turned on while the gpu is in but turns on when It isn't in.I have the 8 pin to 12 pin adapter that came with the card and it isn't turning on. Can anyone help please
I have the cable plugged into the plug btw
Need help asap
https://linustechtips.com/topic/1329816-gpu-causing-problems-not-to-power-up/
What are the rest of your specs, including the make and model of the PSU? Needed for help.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
The rest of the specs are
CPU:ryzen 7 2700x
Ram:gskill  aegis 2x8gb 3200 ddr4
MB:Asrock b450 fatality gaming k4
PSU:MSI a650f 80+gold
1 minute ago, Pogan69 said:
The
I would start by checking the connections at the PSU and make sure no wires have pulled out.
System specs below
PSU: Corsair CX650M
We have checked them and have looked at the manual and it says that for the power consumption of a 3070 I would have to use VGA 1 and 2 but the card only powers through the adapter which is only 8 pin and to connect vga 1 and 2 ID need 12 pins
Nevermind we fixed it buy putting a 6+2 instead of the 8 pin we had in the adapter... apologies
I see, you had the wrong cable plugged in.
System specs below
PSU: Corsair CX650M
