Recently my parents told me I have a budget of $1500 USD before tax to spend buying a new computer.  I have now been researching for about four days now and think I have a pretty good list of compatible parts, Figured here would be a good place to check and maybe do some final swaps in my selection. (Here's the list)1209747456_Comp.partspt1.thumb.png.8549a01adeea261d7dee5b25ccbc7764.png2007094325_Comp.partspt2.thumb.png.ff79c1eedb39ca53aa550dc0382cd6e2.png
https://linustechtips.com/topic/1329690-help-building-a-computer/
Since the 5600x is way over MSRP, I'd recommend the 11600K and a MSI Z590 A Pro. Other than that, looks good. Although I'd really recommend going used for the graphics card because that is 3x the regular price.
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
<-- Moved to New Builds and Planning -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
i wouldnt buy this build personally
case: it's ok, a bit expensive for this kind of build but it's a good case
fans: not needed, i would think
CPU: spending a bit much on it, how about a 3600/10400f? lower IPC but it's still great
cooler: if you go 3600/10400f, use the stock cooler, save some cash for other parts
mobo: do you need x570? there are cheaper alternatives
RAM: sure, i would grab 32gb personally, but 16gb is fine
SSD: sure
GPU: remember all the money you saved? dump it here, majority of the games are GPU dependent, so better GPU = more fps
though GPU pricing is screwy right now, i wouldnt recommend buying a GPU for gaming today unless you can nab one at MSRP
PSU: no comment because im not familiar with PSUs
-sigh- feeling like I'm being too negative lately
Put a back order for this GPU, if not then honestly get a cheap used GPU like a 1060 or rx 570 for 200 - 300 and then when prices come back to normal get a 3060ti
geometry is hard
b550 > x570
