Hi:)
I'm looking at upgrading the cooling in my PC, especially a water cooler for my CPU.
I have a Cooler Master Masterbox Q300L and was looking to put a Corsair Hydro H100i RGB PRO XT in the front since I don't have any cooling in that space atm, I'm just worried since it's my first solo upgrade for my pc, and was wondering if anyone can confirm that it fits there or if I should do anything different.
Thanks in advance!
https://linustechtips.com/topic/1329210-cooling-for-my-pc/
It should fit in the front, yes. But if you have a very long GPU it might not be enough room.
If thats the case, you can just mount it on the top, and move those fans to the front
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
https://linustechtips.com/topic/1329210-cooling-for-my-pc/#findComment-14666175
8 hours ago, dani133f said:
My CPU is an Intel Core i-5 9400F
The 9400F is very easy to cool and the stock cooler should be fine Why are you considering such a beefier cooler?
https://linustechtips.com/topic/1329210-cooling-for-my-pc/#findComment-14668060
15 hours ago, dani133f said:
My GPU is a Gigabyte gtx 1660 super
That wouldn't be a problem.
I agree with this.
Water cooling is cool and all, but its expensive compared to what you gain from it in your case.
If your temps are high, save your money and go for a cheaper air cooler, something along the line of Cooler Master Hyper 212. It will still serve you well if you upgrade your CPU in the future.
They are also easier to maintain and will work passively to a certain degree should the fan fail. If an AIO fails it will not passively cool your CPU
https://linustechtips.com/topic/1329210-cooling-for-my-pc/#findComment-14668809
