Description of Problem: I've recently had some issues with my new PC build (about 3 months old) where it has been recently been real inconsistent with POST/BOOT to windows (sometimes it'll take like 10 retries to get it to POST). After reading loads of forums etc. I'm basically thinking that it's due to unstable RAM. I noticed in event viewer that I've been having Kernel Power 41 Critical Errors since the day I built the PC.
Troubleshooting: One thing I've done already is turned off the DOCP/XMP profile in BIOS so that the RAM is running at the default speed before profiles are applied (from 3600MHZ on DOCP to 2666mhz without profiles). I suspected that my MOBO was not liking the RAM running at that speed (I had timings and voltages on auto too). Will running the RAM at this base value help increase stability? I'm hoping that I might be able to go a few days without the issues returning, if so, this tells me it was a RAM issue. I can always have a play around with timings later on if this fixes my issues. I really need this PC for work so any ideas will be appreciated.
GPU: Radeon R9 280X
CPU: RYZEN 9 5900X
Motherboard: ASUS CROSSHAIR VIII HERO
BIOS Version: 2311
RAM: 32GB CORSAIR VENGEANCE 3600MHZ
PSU: CORSAIR 850W 80+ GOLD FULLY MODULAR
Operating System & Version: WINDOWS 10 HOME
https://linustechtips.com/topic/1328016-inconsistent-postboot-issues/
There's like no way a 5900X on a Crosshair Hero can't run 3600MHz RAM. Something is broken and needs to be RMAed.
Ensure you have the RAM in the right slots (usually 2 and 4, but consult the mobo manual). If it is, then try a different kit (within return window) and/or RMA your existing kit.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
Checked my mobo manual and they're definitely in the right slots (2 and 4). Do you not think it could be an issue with the voltages being out of whack? I ran a Windows Memory Diagnostic and it came up with no issues on the memory. I could try buying another RAM kit and seeing if this fixes the issue if the POST issue returns, so far today (I turned off DOCP yesterday) it's been booting fine.
Really appreciate your reply.
You can try making sure you have the latest BIOS revision, and then doing a factory reset on the board, just in case you accidentally fat fingered something in the BIOS, but that board especially is going to come out of the box ready for pretty much anything.
I'm currently on BIOS 2311 which was I think one of the early BIOS for zen 3 on the x570 boards. There have been 7 new BIOS updates since the one I'm currently on. What would a factory reset entail?
