Tried a bit of quickminer after the video Linus did on the topic. I've connected my Coinbase account, but I cannot withdraw anything to that wallet? It says it's successful but then just fails and reset everything back to the Nicehash wallet.
Anyone else having this problem? Is it temporary or is there something wrong? I haven't heard back from any support on the ticket I sent in, so I'm a bit worried since there's so many talking about how trash people behind Nicehash is. So trying to not be scammed by them while doing this.
https://linustechtips.com/topic/1328001-nicehash-withdrawal-problems/
I don't use NiceHash or Coinbase at the moment, but any particular error message that you get? I'd start with the usual: do you have enough funds and are all the addresses correct.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
Yes, I have enough funds and everything is setup correctly, including the 24h wait time for linking to the Coinbase account. I get an error message on my dashboard saying "failure", that's it. There's no reference to any problem, it just says "fail" and after a while the "pending" transfer withdrawal sum gets reset back to the Nicehash wallet. So I'm not losing any coins, it just resets back to the Nicehash wallet without any note of why.
Have you verified your Coinbase account? I don't actively recall if withdrawals from NH/to CB require KYC, but if so and if you're above any minimum amount and have verified you account then it is perhaps a temporary issue, I don't see anything announced on their social media. Maybe just keep trying every now and then.
Yes, verified in Nicehash and there was a 24h waiting time before I could access withdrawals, but it doesn't work.
Is there anything I need to verify on my Coinbase account as well?
You can check the "Account limits" section in your Coinbase settings. Digging through their FAQ you may need to  complete KYC there as well if you're in the EU (and perhaps everywhere):
Quote
What account level allows me to send and receive on the blockchain?
You will need to unlock level 3 by verifying a valid Identification Document before being able to make sends and receive on the blockchain.
