front audio jack not working
Solved by Matszhie,
If you do not have realtek hd audio manager, you can download it from the official website https://www.realtek.com/en/downloads
I personally would not know if supremefx provides the same features, so even if you were to be able to do the same things, I wouldn't know how to enable/disable the auto detection. So you could try using the realtek hd audio manager from their official website.
