ram Would different storage space RAMs with same frequency work fine?
Solved by AnirbanG007,
1 minute ago, Mahmudul Hasan said:Okay. Can you explain why it would not be dual channel all the way since the frequency matches on both?
Because they are of different capacities. Let's divide the 16 gb of G.Skill into 2, 8 gb's, one of the 8 gb's will run in dual channel mode with the Corsair 8 gb stick, so you do get dual channel, but the remaining 8 gb on the G.Skill will run in single channel. This is called Flex Mode.
