1 hour ago, Neoquazar824 said:
sorry for late reply but, I can not do that, I have the option for fans always on but 😕
Then speedfan will not help you if BIOS is not capable of controlling fan speed, I personally have 2 old PC that have the same issue. I solved it by just buying some low noise adapters from noctua to get the noise down, still not controllable though. That is if noise is your concern here.
Full time technology enthusiast, part time IT.
https://linustechtips.com/topic/1327448-speedfan-help/#findComment-14655516
ok thx 🙂 Cooling is my problem (laptop gamer lol)
https://linustechtips.com/topic/1327448-speedfan-help/#findComment-14659259
