Need help with connecting asus rog strix 360 rgb aio to asus z590 a gaming edition.
Rohan6M
Need help with connecting aio to motherboard, I am not sure what screw to use, the motherboard is lga1200 and is compatible with my aio but in the manual it says to use screws for lga 115x/1366 or screws for lga 2011/2011-3/2066, which screws do I use for the standoffs backplate?
Found out that I have to use the screws for lga 115x but there is still some wiggle room for the screws on the mobo/cpu backplate?
I can’t screw them in anymore and tried screwing them in both ways
LGA 1200 and 115x share mounting.
As for the wiggle room, did you use the washers?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
