Gpu make weird sound
Go to solution Solved by Helpful Tech Witch,
1 minute ago, POG Gamer said:
ohh ok, is that bad I know it's not hitting something because it happens sometimes
Can you take the side pannrlnoff and take a picture?
my gpu is making this weird sound (see videos) Not sure if it is coil wine and a problem with the card
the videos: https://drive.google.com/file/d/1_HNEHp1lYNHp0llW3hX1B9tx-MpsmtN_/view?usp=sharing, https://drive.google.com/file/d/1u4ua6oI3H7YNMJG6DgDEScDOxoudqF1q/view?usp=sharing
this is my pc partpicker https://pcpartpicker.com/list/LQgVy4
thank you for who ever helps me
KanyeWestLover911
Reminder
I'm just speaking from experience so what I say may not work 100%
I Use Arch BTW
my PCs
these are my Pcs
https://pcpartpicker.com/user/mtj08/saved/
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/
You need to change the files to anyone with the link can view.
Both drive files are no access for me.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14650337
fixed https://drive.google.com/file/d/1_HNEHp1lYNHp0llW3hX1B9tx-MpsmtN_/view?usp=sharing, https://drive.google.com/file/d/1u4ua6oI3H7YNMJG6DgDEScDOxoudqF1q/view?usp=sharing
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14650338
Bios database
prior build:
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14650352
3 minutes ago, HelpfulTechWizard said:
No that's a fan hitting something or vibrating.
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14650357
Bios database
prior build:
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14650360
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14650379
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14652431
I'd bet this
is the problem
Bios database
prior build:
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14675271
44 minutes ago, HelpfulTechWizard said:
I'd bet this
is the problem
ok thank you
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
https://linustechtips.com/topic/1327046-gpu-make-weird-sound/#findComment-14675330
