Its my first PC build
Solved by Analog,
1 minute ago, xanderl said:Budget (including currency): € 1000
Country: belguim
Games, programs or workloads that it will be used for: make animations, adobe, minecraft, panet zoo, hitman 3
Other details
AMD Ryzen 5 3600, 3,6 GHz (4,2 GHz Turbo Boost) socket AM4 processorAORUS X570 ELITE, socket AM4 motherbordCorsair 16 GB DDR4-2666 Kit RAMWD Blue, 1 TB hard driveAerocool Bolt tower-caseMicrosoft Windows 10 Home 64bit softwarebe quiet! System Power 9 CM 500W power suplieADATA SWORDFISH, 256 GB SSDMSI GeForce GTX 1050 Ti 4GT OC GPUDo anyone know how I can get windows for a cheaper price (legal).If you have any tips let them know.Whit vriendly greeting,Xander
Unless you need the added features of X570, which judging by your build, you don't seem to, it will be much better to get a B550 board and with the spare cash upgrade the memory to something that is 3600MHz instead. There are legitimate performance benefits from faster memory on Ryzen. That power supply is also not that good, quality wise. Recommend getting something with 80+ Gold certification.
